upgrade 6036e
is there an upgrade procedure for 6036e ?
We must replace a PCI 6036e daq card in an old labVIEW 8.6 system
(4,389 Views)
It looks like NI is suggesting to replace the PCI-6036E with a PCIe-6341.  As far as your software is concerned, just make sure the DAQmx device alias is set correctly in MAX and it should be fine.  Hardware wise, you may need to change connectors and watch for pin changes.
(4,384 Views)
