Zero strain readings at the start of a test using Daq Assistant
Hi James.
          I have been working on this circuit for quite a while. I am using two DAQ Assistants to read strain from CH0 and CH1 of NI 9237 ( DAQ Assistant  is reading CH0 and DAQ Assistant 2 is reading strain from CH1). But everytime i run it i am getting a error " 50103 : The specified resource is reserved ".. what does this mean??.. i have also used a merge option to combine both the graphs in a single Plot. Kindly help me out in figuring this. I have a project due next week. really appreciate it.
I have also Attached the VI.. kindly have a look at it
Message 21 of 34
(2,093 Views)
Do NOT use two daq assistants. This is a common error that beginners make and has been discussed numerous times. Use a single assistant with both channels in it. You missed the instructions on how to do this when you created the first assistant but it's easily fixed by opening the first up and clicking on the Add button.
Message 22 of 34
(2,088 Views)
Hi dennis,
          I tried that but how do i make them both zero at the start of the experiment once i hit tare button??.. i want them to start with both the strains zero.
Message 23 of 34
(2,079 Views)
Then save the values in two shift registers instead of one like was shown earlier. I never use the evil dynamic data or the daq assistant but you can use the split signal function to get each channel.
Message 24 of 34
(2,073 Views)
Thanks Dennis. worked perfectly
Message 25 of 34
(2,059 Views)
Hi Dennis,
               Thank you for the earlier help. I got two seperate signals in a single graph. But now i want to plot strain 1 data on x axis and strain 2 data on y axis instead of strain 1 and 2 both on y axis so that i get a linear graph for same deflection on both the gauges. Attached is the VI that works well. Can you please tell me how to plot one strain value on x axis and another on y axis in the same graph?
Message 26 of 34
(2,048 Views)
Instead of the Waveform Graph type, use the XY Graph.  This way you can bundle together the two data, and it will plot one on the X axis and one on the Y.  I would look through the help documentation on the various types of graphs.
-Jim B
Applications Engineer, National Instruments
CLD, CTD
Message 27 of 34
(2,045 Views)
Hi James,
           I tried bundling the two signals and plotting them on an XY graph. But it is giving me an error " connection of channels of two different types ".
How i get the XY plot?
Message 28 of 34
(2,034 Views)
Please attach an image of your block diagram do someone can see your mistake.
Message 29 of 34
(2,031 Views)
Here is the block Diagram. I am getting a straight line on X and Y axis. no graph is displayed
Message 30 of 34
(2,027 Views)
