about pressure drop measuring in hydaulics/pneumatic components
i am doing a project on measuring the pressure drop and response time in pneumatics/hydraulics ... i want your help in guiding me about any devices availble fot it or any ideas ..... thank you
(3,083 Views)
Are you using Pressure sensor with (4 to 20 mA output)?
The basic features that you need to specify before buying a DAQ systems are:
- Sample Rate
- Number of Channels
- Distributed I/O or not
If the Sample Rate is not too fast, and you need a distributed I/O, you will probably get away with the Field Point modules. Otherwise, I would advise you to look into the E-series DAQ boards or PXI 4220.
Contact the NI regional sales office to select the appropriate product for your application.
Also refer the following tutorials :
http://zone.ni.com/devzone/cda/tut/p/id/3639
Shreyas Hebbare
Shreyas Technologies
India
(3,068 Views)
