voltage ramp
Hi All,I am trying to use my acquisition card to generate a voltage ramp using LabWindowVCI. To generate this voltage ramp I would like to do the following: 1) use a timer which generates "events" at a regular frequency. This timer is initialized at startup and left alone to run by itself(2) use an "event handler" that detects those events when they happen and calls a ramp function that updates (increases or reduces) the acquisition card analog output. Can anybody help me with this?Thank you very much,Immanuel.
(2,949 Views)
Hi Immanuel,
try to have a look at this example and this post.
I hope it will help!
Bye!
Licia
(2,933 Views)
