access Ain as well as Din at the same time..PCI6013
hi experts,
i will be using a DAQ_StopTrigger_Config() and then Scan_Start() for the analog inputs signal. but at the same time it is important to get the values of the Digital in simultaneousy. Is it possible to do a DIG_Prt_In() from a differnt thread doing a polling based acquisation..or is it possible to do a interrupt based acquistaion in this case..
the application is using a PCI6013 card..and the language used is VC++(NI DAQ)
any help regarding this querry will be appreciated..
thanks..
sumits
(2,395 Views)
It is possible to do Analog Input and Digital Input operations together. You may actually look at the simultaneous AI and AO example in CVI (which is a C file only) at the following link to get an idea. If you need more help please do let me know.
Link 1
Please do let me know if you have any questions.
Sincerely,
Sastry V
(2,395 Views)
