Multifunction DAQ
analog output keeping value after program
I am using a USB 6001 to output a simple analog voltage. Right now I am still in the experimenting stage to see how to control my voltage when I noticed that after I end my program, the DAQ is still outputing the last analog value.
Attached is my VI. I am using the stop and clear commands at the end of the program so I do not understand why it continues to keep the latest value. I used a break point so I know the program is getting to the stop and clear commands.
How do I make the outputs return to 0 when I end the program, assuming there is a way other than writing 0 at the end of the program.
I did not find related articles but if there are please reply with a link.
Thank you very much for any assistance.
Tommy
(5,203 Views)
Accepted by TIcon
The DAQ device is supposed to retain the last value so writing a 0 before clearing the task is the correct method.
(5,191 Views)
I was hoping for a way to reset the entire device to zero rather than having to change each output but at least now I know.
Thank you Dennis.
(5,151 Views)
There is a reset function but since you can write to all channels with a single DAQmx Write, I prefer to do that. It's faster in my experience.
(5,144 Views)
