Multifunction DAQ
analog output plus transconductance amplifier
Hello everybody,
sorry if I put a maybe trivial question but I'm a beginner in data acquisition yet.
I need to output a pulsed negative current from my PCI 6251 and measuring resulting voltage on load at the same time.
To do that, I've thought to ouput a pulsed voltage from AO0, sending the voltage to a transconductance amplifier, and generating a current to my load.
This is my transconductance amplifier... the load, modelled in the square, is referred to the +5V on the PCI 6251 and not to "ground", since I need current to be negative.
Now, I must read voltage on load by means of AI0 and I've got lost among grounding issues... Since the load is referred to my +5V, should I measure it in differential or single ended??
Thanks for your time
Denise
(3,400 Views)
Accepted by Salamandra
Hi Denise,
you have to acquire in differential mode.
See https://www.ni.com/docs/en-US/bundle/pci-pcie-pxi-pxie-usb-62xx-features/resource/m-series-user-manu... pag 4-12
Ciao!
______________________
Simone S.
Academic Field Engineer - Med Region
(3,371 Views)
thanks a lot!
(3,326 Views)
