analog voltage measurement using NI USB-6210
Hello everyone,
I am trying to take a voltage measurement using DAQMX.  I tested this sensor and I am sure that it works.  I keep reading the same voltage when i am touching the sensor, which should not happen. On the other hand, when i use MAX configuration i get the proper reading except it gives me an array of measurements, when i have specified a single point read. Here are the images..
[problematic way]
[using max]
Message Edited by GHernandez on 02-15-2007 12:22 PM
(4,384 Views)
You might want to wire up your indicator to the DAQmx Read output.Smiley Wink
(4,377 Views)
doh, i forgot to wire it before I took the screenshot. I wired it and i am still getting the same voltage reading. 😞
(4,370 Views)
The only real difference I see is with the different ranges you have. Other than that, it looks like you should get the same results. Maybe someone else will see something wrong.
(4,364 Views)
AH, the problem was i didn't configure the type of measurement it was: differential or reference single ended.Smiley Sad
It seems to be working now. thanks!!
Message Edited by GHernandez on 02-15-2007 05:15 PM
(4,357 Views)
