at mio 16-e driver
Hello
I am looking  windows driver for DAQ card AT-MIO-16 version E, but I didn t find it. It is an old DAQ card.
I need driver for windows xp or windows 2000.
Can somebody help me.
Primoz
(3,401 Views)
This table will help you to find the appropriate driver and this document to identify the exact type of your card.
Message Edité par JB le 07-25-2007 09:46 AM
(3,401 Views)
Because you have an E series, the second link is not useful !
(3,395 Views)
Hello Primoz,
The AT-MIO-16 has many different models. Only the Plug and Play E-Series models have a driver for Windows 2000 or XP.  You can find more info under the link JB posted.  You will specifically want to look at the Plug and Play ISA/PC/AT section.  One other factor to consider is how you will be using the board.  Are you working with LabVIEW or another programming language? You will want to make sure the driver also provides support for your programming environment.
If you need further advice on the version of the Traditional DAQ driver to install, please post back with the exact model number and how you will be using the card (i.e. LabVIEW version x.x or otherwise).
Jennifer O.
(3,378 Views)
