03-03-2009 01:17 PM
03-05-2009 10:04 AM
drakerebel,
The NI 9172 is a cDAQ chassis. To be more helpful I would need to know what modules inside the chassis you have.
Either way if I were you I would take a look at the Cont Acq Thermocouple Samples-Int Clk.VI. This is an example program that will show you how to constantly read from your thermocouples. I would then merge this with the Cont Gen Voltage Waveform.VI. You will then change this analog signal based on the output of the thermocouple.
