cannot do daq after trigger
I am doing a project and using PCI6071E and traditionanl DAQ  for data acquisition.
What I want to do is : When the input signal level is between some values, the trigger generate, and daq start, and then get some samples into buffer. The pesudecode is like following:
  Configure_HW_Analog_Trigger (1, ND_ON, 52, 54, ND_INSIDE_REGION, ND_THE_AI_CHANNEL); //12bit DAC
DAQ_Config (1, 0, 0);
DAQ_Start (1, 0, 1, DaqBuffer, ---); //sample several samples to buffer
//display the data in buffer
PlotWaveform(-----);
DAQ_Clear(1);
Configure_HW_Analog_Trigger (1, ND_OFF, 52, 54, ND_INSIDE_REGION, ND_THE_AI_CHANNEL);
There seems no response after I run this program with a analog sine input, I vary the voltage of the analog input. I don't know whether I am using "Configure_HW_Analog_Trigger" in right way and confusing about the result.
Message Edited by totally on 03-04-2009 03:33 PM
(3,113 Views)
First of all, what is the development environment that you working in? Also, are you using NI-DAQmx driver? If so, you should definitely follow some of the example code that comes with that driver.  When you install the DAQmx driver, examples for C and .NET install to the following file location: C:\Documents and Settings\All Users\Documents\National Instruments\NI-DAQ\Examples\... There are also examples of how to use triggering for analog input using DAQmx in C and .NET on ni.com. Here is a link to get you started. I would use these as as guidance in developing a working application.
Also, a good resource to make sure that you are using the functions properly is the DAQmx C Reference Help that is installed with the DAQmx driver. You can find this in your start menu in Program Files>>National Instruments>>NI-DAQ>> NI-DAQmx C Reference Help.
Chris W.
(3,096 Views)
