Multifunction DAQ
boole switch set manually and deactivated automatic
How can I set a boole switch manually e.g. to true and reset it automatically after a time delay without blocking the manual setting possibility?
(2,812 Views)
Delay then write to a local of that switch.
The switch needs to have a mechanical action set to latch to function the way you described.
Greg Bush CLAD
(2,809 Views)
