Home
Community
Discussion Forums
Most Active Hardware Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
boole switch set manually and deactivated automatic
pretec
Member
12-21-2004
05:21 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
How can I set a boole switch manually e.g. to true and reset it automatically after a time delay without blocking the manual setting possibility?
0
Kudos
Message
1
of 2
(2,811 Views)
Reply
Re: boole switch set manually and deactivated automatic
bushman
Member
12-21-2004
07:55 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Delay then write to a local of that switch.
The switch needs to have a mechanical action set to latch to function the way you described.
Greg Bush CLAD
0
Kudos
Message
2
of 2
(2,808 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
