03-20-2019 03:29 PM
Can I upgrade the cDAQ OS from Windows 7 to 10? As I'm sure you're aware, January 1st 2020 Microsoft will stop support for Windows 7. My company has requested all cDAQ's me moved to Windows 10.
03-21-2019 09:00 AM
Hi JD,
The supported operating systems for the cDAQ-9133 are Windows Embedded Standard 7 (WES7) and NI Linux Real-Time. I believe you can upgrade from Windows 7 to Windows 10. Feel free to run the Windows Update Troubleshooter; if that doesn't work, I would advise contacting Microsoft as they will be more able to help with this.
Good luck! 🙂
03-21-2019 11:43 AM - edited 03-21-2019 11:49 AM
NI only offers official support for WES7 and Linux RT on the 9133. Due to the limited 16 GB of storage on 9133, upgrading to Windows 10 will be a dicey proposition as minimum requirement for Windows 10 IoT (comparable to Windows Embedded Standard 7) 32-bit is 16 GB and for Windows 10 64-bit is 20 GB. And that is only Windows itself without any NI or third party software.
03-22-2019 11:44 AM - edited 03-22-2019 11:46 AM
FYI, it is not much more, but cDAQ-913xs are using Windows Embedded Standard 7 (SP1), for which the end-of-support date is 10/13/2020.
