Multifunction DAQ
cDAQ-9136 with DAQmx
I have an application written in C/C++ that uses DAQmx totally standalone from LabVIEW to access NI hardware (PCI/USB/CompactDAQ/etc).
I just wanted to check that if I purchase a NI cDAQ-9136 embedded controller with WES 7 that this should basically work "out-the-box" and that the controller will appear in MAX as "cDAQ1" and the C-series modules along the lines of "cDAQ1Mod1" etc. just as if I was using a USB or Ethernet cDAQ module plugged into a "normal" PC.
Thanks, Ben.
(2,149 Views)
Accepted by benbrown
You shouldn't need to modify your C code but you still need to install DAQmx into cDAQ-9136 since software and drivers are not pre-installed.
(2,084 Views)
