Multifunction DAQ
cDAQ 9174 with NI 9213 modules gives Statuscode -88302
Hey Guys,
i don't know if this is the correct section, but i hope i get an answer anyway.
I use 9174 cDAQ in combination with 9213 modules for Thermocouples. The DAQ is connected to a PC via USB. NI Max shows both the DAQ and the Modules. While the Connection to the DAQ seems fine, the Modules show Statuscode -88302: An internal Error occured. The Windows device Manager shows the modules, so i assume it isn't a connection issue. I've tried multiple times Disconnecting, Restarting the PC and DAQ, Restarting NI Device Loader, Reinstall DAQmx, Deleting NI Max Configuration, but nothing worked.
Some further Informations:
DAQmx Version 18.1
Windows 7
(2,978 Views)
Accepted by jan1992
I was able to find this:   https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019LJpSAM
It looks like a possible driver issue.
If that does not help the NI site search shows plenty of results if you search for -88302.
Or do a Google search for:    LabVIEW Status Code 88302
(2,962 Views)
Like i wrote, i did that several times. Took me three days. I upgraded, downgraded, repaired, uninstalled and installed. Somehow it worked, but i can't say why :).
(2,941 Views)
