cDAQ with 2 Slots
Liebe NI Community,
this is my first post in the forum. I would like to ask if there are cDAQ devices with 2 connectors or not. Unfortunately, I could not be found on the NI website.
I thank you in advance!
Best regards
Ali EGIN
(1,369 Views)
I am not aware of any 2 slot cDAQ controllers.  There are 1, 4, 8, and 14 slot controllers.  If you need 2 slots, then get a 4 slot controller.  I would also recommend getting the filler panels to protect the unused connectors just in case you have to expand to use them.
(1,355 Views)
thanks for your answer. Does NI have filter panels that you recommended to me.
(1,333 Views)
NI-9977
(1,324 Views)
