Multifunction DAQ
cRIO 9073 compatibility with NI-DAQmx
It appears that the cRIO-9073 is not compatible with NI-DAQmx.  Is that a true statement or do I have something busted in the installation?  The modules I intend to use are compatible with NI-DAQmx, but I can not connect with them using NI-DAQmx.  I am using LV 2009, MAX 4.6.2, NI-DAQ 9.0 and NI-RIO 3.3.  Suggestions appreciated.
Thanks in advance.
RunningDog
(6,331 Views)
Accepted by RunningDog
The cRIO-9073 is not a DAQ board, it's a real time based system with a reconfigurable FPGA. In a summary: You cannot use NI-DAQmx to program your cRIO system. Please read another post I wrote to see how to get started with a cRIO system.
Luca
(6,304 Views)
Luca P.
Thanks for the comment and the link.
RunningDog
(6,293 Views)
