11-15-2010 03:20 AM
I use a cRIO with an NI 9237 module for the measurement of strain with strain gauges. Here I use the the NI 9944 adapter to connect to strain gauges. I have a large number of SG and spread over a large area, so I have thought about to build little boxes in which four adapters are installed. Now I will not always use 4 RJ50 cable to connect the boxes, just one. This cable should not consist of 40 cores (1x RJ50 = 10 cores), but use only the cables are also needed.
Now my question is what pins of the NI 9944 are even used a to connect a quarter bridge?
I hope someone can help me
Matthias
Solved! Go to Solution.
11-17-2010 02:51 AM
Hi Matthias,
here I have a document which should help you:
http://digital.ni.com/public.nsf/allkb/F47EFDB8B1992282862572AD007CE9C3
:D,
RMathews
11-17-2010 03:20 AM
Thanks Matthias
