Home
Community
Discussion Forums
Most Active Hardware Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
can I make fast SPI-slave using PXI-6534
taaltio2
11-04-2008
07:20 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
can I make fast SPI-slave using PXI-6534. I need to read 2kb bloks with clock rate 5MHz. SPI bus has clock and data signal and PIX-6534 should read data using the external clock signal.
0
Kudos
Message
1
of 1
(2,903 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
