can I make fast SPI-slave using PXI-6534
can I make fast SPI-slave using PXI-6534. I need to read 2kb bloks with clock rate 5MHz. SPI bus has clock and data signal and PIX-6534 should read data using the external clock signal.
Message 1 of 1
(2,904 Views)
