Multifunction DAQ
can bus reading from NI usb 6259
I am working on can bus monitoring and I have a NI USB-6259. is it possible to read data from CanBus with NI USB-6259?
"You live in a graphical world. Why not program in one?"
(3,655 Views)
Veli,
Unfortunately, you cannot monitor the CAN Bus with a USB-6259. However, National Instruments offers multiple USB devices that will allow you to monitor the CAN Bus. Those devices are the USB-8472, USB-8473, and USB-8473s
Larry H.
Applications Engineer
(3,647 Views)
Accepted by VeliBayar
Thanks a lot..
(3,643 Views)
If the CAN-BUS is a serial single wire signal, why could this not be read in the USB-6259, on a digital line or even analog and software sorted to get the messages?
(would be good to know why a device can't be used, and not just that it can't)
j
(3,150 Views)
