can global variable save array?
(3,129 Views)
Greetings,
Yes, global variables can save arrays.
Spencer S.
(3,129 Views)
Yes, you can store an array in a LV global variable. It is not always a great idea to do so. I have attached a very simple example below if this helps. You may also want to take a look at the link below for tips on using global variables judiciously.
http://www.ni.com/devzone/lvzone/dr_vi_archived1.htm
Brent R.
(3,129 Views)
