Multifunction DAQ
can i get an output signal from a NI 6041E (DAQCard-AI-16E-4),
Hi everybody,
i m using a DAQcard AI 16E 4 (NI 6041E)
i can do all my measurements.. but now i would need an output.
So is there any way to get an output signal generated with labview?
thanx a lot for your answer!
(3,039 Views)
As far as I can see in the DAQCard E Series User Manual your card does not hav any output circuitry, so you cannot get an analog output signal.
(3,036 Views)
Hi Roberto,
i really appreciate this quick answer!
i actually read the wrong manual Smiley Sad
Greets from Germany
(3,033 Views)
