Home
Community
Discussion Forums
Most Active Hardware Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
can i get an output signal from a NI 6041E (DAQCard-AI-16E-4),
aj109
Member
04-04-2008
09:09 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Hi everybody,
i m using a DAQcard AI 16E 4 (NI 6041E)
i can do all my measurements.. but now i would need an output.
So is there any way to get an output signal generated with labview?
thanx a lot for your answer!
0
Kudos
Message
1
of 3
(3,034 Views)
Reply
Re: can i get an output signal from a NI 6041E (DAQCard-AI-16E-4),
RobertoBozzolo
Proven Zealot
04-04-2008
09:28 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
As far as I can see in the
DAQCard E Series User Manual
your card does not hav any output circuitry, so you cannot get an analog output signal.
0
Kudos
Message
2
of 3
(3,031 Views)
Reply
aj109
Member
Author
04-04-2008
09:36 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Hi Roberto,
i really appreciate this quick answer!
i actually read the wrong manual
Greets from Germany
0
Kudos
Message
3
of 3
(3,028 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
