can i use DAQ to control robot pick hand and some other project with DAQ
harlow~, i 'm jin student in degree, i'm looking some idea for my final year project using DAQ.
 i would to know whether i can use DAQ to control a robot pick hand. As i know, DAQ can be use for control simulation.
do anyone have other project can be done with DAQ?
thanks you for ur kindness information~~
(3,005 Views)
Hi kannajin,
There are many ways you can use DAQ in a project.  If you want to control a robotic arm, you can use the DAQ device analog outputs to control the motor drives that power the motors.  You could also use one of our motion control systems.  The link below is to the Student Corner on our Developer Zone.  There are many more resources for students there.  If you give a bit more detail about the requirements of your project and your major, I'd be happy to give you more adivce.
Student Corner - Developer Zone
http://zone.ni.com/devzone/cda/tut/p/id/5058
Motion Control
http://www.ni.com/motion/
Data Acquisition Hardware
http://www.ni.com/dataacquisition/
John Bongaarts
(2,988 Views)
thank you~~
if i have any problem, i will try to get consultan from u!!
(2,983 Views)
