I'm working on a LabVIEW VI to acquire signals from 16 microphones. However, once I set everything up I find that I'm only able to obtain the input from 1 channel. I've also noted that the channel that works keeps changing as well, for example on my VI it was channel ai4 that works, and on a LabVIEW example it was channel ai8. This is very strange.To check whether all the channels were working, I first sent individual signals (from a function generator) to the input terminals and they did produce the waveforms as expected. Secondly I connected four signals from the function generator to the input terminals, and these four channels produced the waveforms as expected.
To check my microphones, I connected them upto an oscilloscope and found out that I could not get any signals. However, when I connected the microphones to my computer directly, I was able to get signals from it.
I think my problem is not with the NI Devices or LabVIEW. If I can figure out why I'm not obtaining any microphone signals on the oscilloscope then maybe I can figure out why I'm obtaining inputs from only 1 channel. To be honest, I'm really confused now and don't know what else I could do. Any suggestions will be helpful.
The devices I'm using are PCI 6229, BNC-2090 terminal and the microphones are simple tie-clip ones.
