can start one task with two outputs from the same noard?
Hi Is it possible to start a task with two analog outputs from the same NI DAQ board?
I have run in errors.
They can be  -2001003 and -200524.
 Please advise
(2,964 Views)
Yes you can start but you need to use the proper terminal configuration as wells proper i/o selection. Try posting the code which is throwing error and by the way which DAQ card you are using?
(2,950 Views)
Hi thanks.
Since you say that it is possible to work. Let me try and work out.
Thanks again
 Clement
(2,935 Views)
