how to generate 2 Mhz frequency using pci-6259?
hello, im trying to generate 2 Mhz frequency signal in labwiew software. but if i increase the frequency above 500 Hz it shows error "error 20061". plese find attachment with this post. n help me to remove the error.
(3,217 Views)
It looks to me like the default sampling information on the square wave.vi is set to a sampling rate of 1000, your output will be limited to 500Hz.  The frequency output of the Square Wave.vi is limited to fs/2.  If I add a cluster constant for the sampling info and change the fs to 2000 then I can output a 1000Hz signal.
Hope this helps.
Steven M.
(3,206 Views)
You really are not going to get there with the PCI 6259.  Yes is has an update rate of 2.8MHz.  It also has a min rail-rail settle time of 2uSec.  This mean if you start going above 250KHZ the output simply cannot slew fast enough and will be distorted and attenuated.
(3,197 Views)
Jeff:
Would a high speed buffer or schmidt (sp?) connected to the output improve performance?
-AK2DM
(3,185 Views)
