cb 68 t nd thermistors connection
Hi, i'm using a Cb 68 t connected to PXI 4351. To this board i've connected 14 thermistors. The termistors have 2 wires because they don't need the 3rd or 4th wire for the parasist current. I have this problem from ch8 to ch 15 the resistance values are read correctly, instead from 2 ch to 7 ch the resistance values are read around zero or as a negative values.
The thermistors at 25 °C release 30 kOhm, and i'm sure that my thermistors run correctlt because i've checked them by a multimeter.
Can someone help me?
Have a nice time
Ema
(2,994 Views)
Hi Ema,
first of all make sure you have installed the last versions of the drivers required by PXI-4351 (TraditionalDAQ 7.4.4 and NI-435x 2.5.2). Also check that the terminal block is correctly installed (see the manual here) and all is properly connected.
Are you obtaining those readings in Measurement & Automation Explorer or in your software? In this last case, please check also the readings you obtain in MAX (to be sure it is not a software problem).
What option are you selecting for CJC sensor?
Did the board ever worked fine? Have you tried it also in another slot or with different cables?
Bye!
Licia
(2,974 Views)
