Home
Community
Discussion Forums
Most Active Hardware Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
chirp signal with ni pci 6259
Naser1363
02-01-2010
05:07 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I want to generate a chirp signal with NI PCI 6259 in interval frequency [10KHz-200KHz]. Would you please tell me can I use NI PCI 6259 to generate this chirp signal. Thank you
0
Kudos
Message
1
of 2
(3,167 Views)
Reply
Re: chirp signal with ni pci 6259
HeatherBaker
NI Employee (retired)
02-02-2010
04:11 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
The update rate is
2.86 MS/s
which is 10 times the maximum frequency so it should be okay. This
document
might also help you.
h_baker
0
Kudos
Message
2
of 2
(3,142 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
