connect labveiw 8.2 with ni pci-6251
hi,
can i download labview fpga module 8 or labview fpga module 8.2  ??????????
please reply........
Message 11 of 29
(2,671 Views)
hi,
I need labview fpga module v.7 or later, can i download this software from ni web site.
if it is avaliable give me the link to download this software....
please reply..........
thanks.........
Message 12 of 29
(2,648 Views)
   Can I plot state trajectory of a system responce using labview program.
please reply......
Message 13 of 29
(2,557 Views)
Hello sddd,
I am a little unclear as to what you want to plot.  Are you doing this in software?  If so you can use our PID toolkit to find system responses.  You can also use the Control Design and Simulation Module to model systems.  You can read about that here.
Also, this forum is a little stale.  You might get better results if you write in a new thread that does not already have an accepted solution.  That way, you won't have to write please respond after every post. 😉
ColeR
Field Engineer
Message 14 of 29
(2,537 Views)
I need to send data from pc to spartan 3e fpga through ethernet port using labview fpga module.
can I do this task?
thanks.....
Message 15 of 29
(2,376 Views)
Yes you can (or maybe no you cannot), but this isn't the forum that you will get the answer from.  Create a new post on the LabVIEW FPGA Board to find more users that would have experience with this.  This post is no longer even related to the original title.
ColeR
Field Engineer
Message 16 of 29
(2,366 Views)
I have ni pci-6251. How can i  connect this DAQ with labview 2009 and run programs?
When installing NI device drive, there are aproblem is apear. The software can't recognize input output channels.
thanks for reply....
Message 17 of 29
(2,137 Views)
Hi MMH,
Have you installed a newer version of DAQmx since you upgraded to LabVIEW 2009? What version of DAQmx are you using? What problems are you referring to when installing device drivers?
Matt
Message 18 of 29
(2,105 Views)
I installed NI device DVD that appendix with NI LabVIEW 2009 software, but when adding input output DAQ channels to the my program, the message there are no DAQ is appears.
thanks for reply............
Message 19 of 29
(2,097 Views)
I’m sorry MMH, I’m a bit clear as to what you are seeing. Is this the screen you are refereeing to?
Does the PCI 6251 show up in Measurement and Automation Explorer under Devices and interfaces?
Matt
Message 20 of 29
(2,088 Views)
