Multifunction DAQ
connect sensor (0 to 5Vdc analog output and 9-28Vdc supply) to NI 9219
Hi Voon,
I haven't had much experience with pressure sensor, but I am guessing there is some kind of conversion from pressure unit (bar? psi?) into voltage?
You can convert the voltage data into pressure data by several methods, few that I can think of:
1. DAQmx Scale
--> Go to MAX>>My System>>Scale>>Create New
--> Then fill in which conversion type suite you based on the sensor manual, save the scale
--> In LabVIEW, if you use DAQ Assistant, use Custom Scaling and use the saved scale previously
2. LabVIEW
--> If you acquire the data in LabVIEW then you can create a 'conversion' formula in LabVIEW
Hope it helps.
Sincerely,
Krisna
Certified LabVIEW Developer (CLD)
Certified TestStand Developer (CTD)
Using LabVIEW 8.5.1 (2008) to LabVIEW 2024
Message 11 of 12
(755 Views)
Hi krisna,
Ya, I follow the step you given to create the new scale in MAX. I m using the calibration datasheet for sensor calibration to plot and get the XY-equation. I am not sure whether I m doing it correctly.
Anyway, thanks ya.
Best Regards,
Voon Loong
Message 12 of 12
(748 Views)
