04-07-2008 12:18 PM
04-09-2008 03:56 PM
The pinout for the PCI 6251 is located in the M Series User Manual on page A-67. The pin numbers can be aligned with screw terminal numbers on the TBX-68. The pinouts are also located in the Measurement and Automation Explorer (MAX) under Devices and Interfaces, NI DAQmx Devices, right click on the device of interest, and select Device Pinouts.
