connections tbx68
I have a PCI 6251 and a TBX68.  How do I configure the TBX68 and the 6251?  Which connection diagram do I use?
(3,406 Views)
The pinout for the PCI 6251 is located in the M Series User Manual on page A-67.  The pin numbers can be aligned with screw terminal numbers on the TBX-68.  The pinouts are also located in the Measurement and Automation Explorer (MAX) under Devices and Interfaces, NI DAQmx Devices, right click on the device of interest, and select Device Pinouts.
Samantha
(3,383 Views)
