control power suplies by PXI 6733
I´m a new Labview user. I need to control 4 power suplies with a PXI- 6733, this power suplies have a analog input (0-10 V) and I have to start with a digital trigger (I have a PXI-6254 too). How can I do it?
Thanks a lot.
(2,865 Views)
The PXI-6733 has 8 output channels with a range of -10V +10V and digital triggering, so you will not need to use the PXI-6254. There are some examples of triggering in labView that can show you how to do it (there is a good example in the HELP menu, FIND EXAMPLES..., and then open HANDWARE INPUT AND OUTPUT >> DAQmx >> ANALOG GENERATION >> VOLTAGE >> CONT GEN VOLTAGE WFM-INT CLK-DIG START.vi)
Hope this helps.
Angel M. Sendin
(2,846 Views)
