control the while lopp
hi
i want to control my while loop but i am unable to control it
i want to integrate two inputs to stop the loop while
when i press the stop button and when the one input to the DAQ  falls below 3 volts
plz help me
Message 1 of 13
(5,185 Views)
You just have to use the OR function.
Very basic question. Have you done the LabVIEW tutorial?
Message 2 of 13
(5,183 Views)
it is not the simple one
i have tried it using the or function but no results
Message 3 of 13
(5,175 Views)
Then attach your code.
Message 4 of 13
(5,172 Views)
kindly look at it
and help i want that when the voltage at waveform  chart become three or i pree the stop button it should stop working
plz look and help me
Message 5 of 13
(5,168 Views)
If you want to compare all three waveforms, use the Compound Arithmetic function on the Boolean palette. You can expand it for multiple inputs.
A less than function can be wired directly to each waveform. Wire a constant to the other input.If you don't change the comparison type, connect an OR Array Elements to the output of the Less Than.
p.s. And next time you say you have a problem with a VI, attach the VI with the problem. Pretty hard to tell you what you've done wrong when you don't attach the non-working program.
Message 6 of 13
(5,161 Views)
i am unable to do it
plz do it for me
plz
Message 7 of 13
(5,154 Views)
This is not a place to get your code written for you. At least show what does not work. It will show that you are at least trying.
And take the tutorial I pointed you to.
Message 8 of 13
(5,151 Views)
i am trying but stuck badly in it
i have send you the code atleast you can correct it as per my needs
Message 9 of 13
(5,148 Views)
The code you sent has no comparisons and no OR function.
Message 10 of 13
(5,146 Views)
