control the while lopp
i want that when the value (voltage) drops to 3 volts at wave form one or i press the stop button the while loop should stop working
i have changed the sampling rates. please set it as it loggs the data after every one second
Message 11 of 13
(1,264 Views)
Accepted by data logging
There's not a single thing you did correctly. Your comparison function was wired up backwards and you did not use the OR Array Elements at all. Are you even working with the Context Help window open?
Message 12 of 13
(1,261 Views)
you are guiding me in great direction . can you just see the data rates with which i can logg the data after evrey one second please
Message 13 of 13
(1,253 Views)
