daq reset after regular intervals
Currently I am using NI 6071E Daq Card, connected to 5 analog channels reading external sensors.
the drivers seemed to work fine for a while.
however quite recently the values read from the DAQ card read '0' values for a
few micro seconds and get back to normal . the external sensors are also working perfectly fine.
This happens very abruptly and does not follow a regular pattern.
could any one suggest how this could be prevented .
Sundar.
(3,233 Views)
Is it possible that your task is continuous and your buffer is on the edge of overflowing?  Just a guess.
Kudos and Accepted as Solution are welcome!
(3,179 Views)
