storing of analog input voltage waveform-Reg
Dear Sir,
  I am new to this LabVIEW. I am using BNC 2120 for getting analog input voltage. I succesfully got the input AC voltage from 3-6V which is exactly the output of my application. But i am also in the need of storing that waveform.So can u please tell me how to store that waveform in LabVIEW Software.
With thanks in advance,
Suresh
(3,015 Views)
Use Write to Spreadsheet File, Write to Measurement File, Export Waveforms to Spreadsheet File, Write to Text File, Write to Binary File, etc. There are numerous options on the File I/O palette and examples that demonstrate how to use them along with descriptions in the help. Decide which format that you want and try some of the them.
p.s. If you ever need help with DAQ, provide the actual DAQ device. The BNC 2120 is a dumb terminal block and can not acquire anything.
(3,006 Views)
