Multifunction DAQ
daqmx clear task
Hello Experts,
attached please find a litte auxiliary DI loop which I use in a larger application. The DAQmx-task is created in the LabVIEW project.
- Can I use it as in Version_A                                          OR
- Do I have to close the task as in Version_B    ??
Somebody once hinted I could create a memory leak using the A-version - is that correct ?
HU
(4,247 Views)
Hi, the right way would be like this
regards
Marco Brauner NIG
(4,214 Views)
Accepted by hurban
Many thanks / Vielen Dank für die kurze und präzise Antwort !
HU
(4,199 Views)
The idea is to mark as 'Accepted Solution', the answer that solved your problem - not your thank you. You can use the Options button to change that.
(4,194 Views)
