data acquisiton with pci 6251 board !!!
I am currently trying to acquire my system's voltage and current values from four channels with PCI-6251 DAQmx card at a sampling rate of 20000 S/sec. My program works 10 sec and collects 200000 samples.I would like to be able to save the incoming signals in a matrix (each column correspond to one input) that I want to use in MATLAB order to do some further off line calculation.
I have been able to display the graphs. I have saved some data into the MATLAB format BUT when I started the labview program that i have made, it acquires the signals very bad. I think there is a loss of data during the acquisition.
I have attached my acquisition VI and the picture of data acquired front panel linked to it. If someone can tell me what to do, I would greatly appreciate.
volkan.
(3,668 Views)
sorry i forgat VI attachment
(3,685 Views)
and screen capture of my steady signals, as you see there is transient parts in some places. but in real system there is not..they must be pure sinusoidal
(3,662 Views)
Hello Volkan,
I looked at your VI and used it with many different signals (PCI-6251). It worked great. I didn't get any transient responses. Could you please run the attached VI and test only one channel and gradually increase the number of channels used to see the response. The M series card has the capability of sampling up to 1.25MS/s, so when using 4 channels, you could sample up to 312KS/s. You should not be seeing this clipping with the sampling rate you are using (20KS/s). Please monitor the signals that you are feeding into your DAQ card with a scope to see if the signals are clipped. Also, please check test the different channels in MAX to see if each channel is functioning properly. A test of your task should reveal if any of the channels is malfunctioning.
Thank you.
(3,626 Views)
Sorry I forgot to attach the VI.
(3,604 Views)
