03-15-2005 12:37 PM
03-16-2005
03:04 PM
- last edited on
07-15-2025
03:36 PM
by
Content Cleaner
Which DAQ driver do you currently have installed in your machine? Which LabVIEW version do you have installed? Have you upgraded your LabVIEW or DAQ driver recently? Which operating system do you currently use? The reason I asked these questions is because this error could possibly occur if you have developed your LabVIEW application in an older version of LabVIEW and NI-DAQ driver, a specific file need to be included in your LabVIEW directory (daqdrv file). The link provided descripes the problem and how to go about solving it. If this does not resolve the issue, please post the DAQ driver and LabVIEW versions and I will be more than happy to research this issue further.
Error -10240 When Running LabVIEW-DAQ Application
Also, in case you have an older DAQ driver installed in your system, it would be a good idea to upgrade to the most recent driver version (NI-DAQ 7.3) which can be downloaded at DAQ Driver
03-16-2005 03:17 PM
03-16-2005 03:19 PM
