data stopped writing to file
Hello; I have been experiencing problems with my system not writing all the data to the file. I am acquiring a signal versus time data. I can see the entire graph on my program which is suppose to be representative to what is to be written to the file, however when I later go in and analyze the data I am not seeing all the data that should be there, it stops after a certain time. I did not get any message idicating a problem and like I said, I know that the program did acquire the data because I could see it when running my program but it is just not writing all the data to file. Any ideas? Labview 5.1, multifunction daq
Corey
(3,087 Views)
This could be a number of things, but are you flushing your output queue to make sure all data is written to the file?
Jamie
(3,080 Views)
Jamie
I appreciate the speedy response. How do you flush the queue to make sure all the output data has been written?
Thanks Again,
Corey
(3,074 Views)
Call fflush() to flush the output queue.
Regards
Jamie Fraser
(3,057 Views)
