pci-6221 card is not recognised with DAQ
I have installed NI DAQ 7.3 and monted a PCI-6221 and PCI-MIO 16E-4 cards. The PCI-6221 is not recognised by the software.
(3,910 Views)
The card is supported by NI-DAQmx 7.3 and should be recognised by the PC without trouble. Can Windows see the card at all?
Check the specification of your PC's Motherboard. M-Series cards require the PCI bus to supply 3.3V, 5V & 12V. Some PCI slots may not provide these required voltages.
Hope this helps!
(3,890 Views)
To be more precise,
http://digital.ni.com/public.nsf/websearch/677E9DEF848CD2A386256F160074C97B?OpenDocument
(3,878 Views)
The mother board of the computer was not supplied with 3.3 V. I made the test on an other computer where all voltages are supplied, the card is then recognised.
(3,867 Views)
Would you mind posting what motherboard you are using? I would like to add this information to the knowledge base we have written to track systems that are not supplying the 3.3V rail. I'd really appreciate it.
thanks,
Nicole
(3,815 Views)
In fact it is a passive back plane on whitch is mounted the mother board. The references of the back plane are : MBP-PCI 13L (31602013065 R2M1E).
Regards
(3,799 Views)
