Multifunction DAQ
digi 5-Port USB AnyWhere Remote USB Over IP Extender in combination with NI USB-6008
Although I don't know about the GPIB-USB-HS specifically, my comments on Trouble connecting USB6211 through USB Extender are probably still relevant.
We do make Ethernet-to-GPIB adapters, and Ethernet and Wireless CompactDAQ products.
These products have been designed to work over an Ethernet network. Our USB products, such as the GPIB-USB-HS, have not.
USB is substantially different from Ethernet (single-client bus vs. multi-client network, different packet size restrictions, different timing restrictions, etc). There are no standards for how a USB-to-Ethernet bridge should operate, so every third-party USB-to-Ethernet bridge works a bit differently, with their own quirks, in how they try to graft the two sides together. Testing every USB product with every third-party USB-to-Ethernet bridge is simply an intractible problem, which is why we discourage using them with NI USB devices.
Brandon Streiff
ni.com/compactdaq · ni.com/daq
Message 11 of 13
(1,311 Views)
Hi, there is DiGI AnywhereUSB-14, from it goes the token to the Hyper-V virtual machine. Everything was fine, but at some point the key began to turn off, and the error continually appears Can not find Remote Hub, tell me someone met this?
Message 12 of 13
(742 Views)
This is a forum for National Instruments products. We don't really have the expertise for diagnosing issues you may have with the Digi AnywhereUSB. Perhaps you should try Digi's support forums?
Brandon Streiff
Message 13 of 13
(731 Views)
