digital signal output multifunction
Hello.
I have a Multifunction DAQ USB-6289 and a Programmable Frequency Scan Waveform Generator, and I would like to use LabVIEW code to output a digital signal using
a 6289 digital output channel (P0.0) and then to the waveform generator.
However my question is: how do I create the digital signal? What are the parameters that come into play?
I have read several DAC and Signal generation topics, but I'm afraid I'm still a bit confused to the question digital vs analog and what are the parameters to produce either...
I appologise for the very basic question but electronics is not my field and I am only using to design system for acquisition of data in pipe flow (chemical engineering).
Hope someone can help.
(3,165 Views)
Keep things to one thread
(3,159 Views)
