discover cDAQ-9181
I'm running windows 7 32bit mod DCHP. I have verified that the discover is enabled, but NI-Max will not find the 9181 module. If I put the 9181 module on a XP system I have no problem in discovering the module. Running N!-DAQ mx 14.5.1 Have tried running in XP compatibility and non XP mode If I configure on an XP system and setup a static IP, I have no problem in running the module on either system
(2,297 Views)
I suggest reinstalling NI-DAQmx on the Windows 7 Computer or force reinstalling it. Also, follow the troubleshooting steps on this KB
(2,266 Views)
