USB 6008 software for data aqusition
I'm just wondering if someone can steer me in the right direction. Looking for simple to use, already made software for my USB6008.  I just need to view multiple analog signals at the same time 0-10v @ 1ms sample rate.
Plus, a bonus would be if I could also set channel output (command) voltages.
I am finding signal express cumbersome & not easy to use. Not sure if it's me, or??? All the other stuff in signal express is unecessary for my needs. Just want a simple start/stop aquisition of differential input signals, and ability to send commands (voltage setpoints) to help me tune PID loops.
Can anyone help?
(2,817 Views)
Accepted by topic author @GG
Hi GG,
I can't speak for third party software, but have you tried DAQExpress? You may find the experience to be less cumbersome using DAQExpress than SignalExpress. There are some pre-made analog input/output examples you can run with that software and the DAQmx driver.
http://www.ni.com/en-us/support/downloads/software-products/download.daqexpress.html#301170
Best,
Ben
Technical Support Engineer
(2,786 Views)
