Multifunction DAQ
USB 6008 software for data aqusition
I'm just wondering if someone can steer me in the right direction. Looking for simple to use, already made software for my USB6008.  I just need to view multiple analog signals at the same time 0-10v @ 1ms sample rate.
Plus, a bonus would be if I could also set channel output (command) voltages.
I am finding signal express cumbersome & not easy to use. Not sure if it's me, or??? All the other stuff in signal express is unecessary for my needs. Just want a simple start/stop aquisition of differential input signals, and ability to send commands (voltage setpoints) to help me tune PID loops.
Can anyone help?
(2,903 Views)
Accepted by @GG
Hi GG,
I can't speak for third party software, but have you tried DAQExpress? You may find the experience to be less cumbersome using DAQExpress than SignalExpress. There are some pre-made analog input/output examples you can run with that software and the DAQmx driver.
http://www.ni.com/en-us/support/downloads/software-products/download.daqexpress.html#301170
Best,
Ben
Technical Support Engineer
(2,872 Views)
